Edit EXIF?
Re: Edit EXIF?
pulancho wrote: Sun Jun 29, 2025 2:18 am While in the browser view you changed the EXIF and then opened the photo into the full size view and the EXIF info displayed in the upper left corner shows all the changes you made?
yes, not you?
pulancho
Re: Edit EXIF?
Post by pulancho »
No, it does not change it for me. Here are some screenshots. By the way, I am still using an M2 Pro 12/19 Mac, MacOS 15.5.
EXIF info before I change it:
Preparing to edit the EXIF:
I then clicked on Apply and it indicated that it was writing the data.
Displaying the EXIF info after I changed it:
This is just an experiment. Of course, for this HIF photo I do not actually want to change the EXIF. :)
Re: Edit EXIF?
Focal length is a number not string
pulancho
Re: Edit EXIF?
Post by pulancho »
Ahh, yes you are right.
Therefore this should work?
pulancho
Re: Edit EXIF?
Post by pulancho »
Hmm, that didn't work. I still get the original EXIF info.
Re: Edit EXIF?
strange it works with your file, try to change only make or model
pulancho
Re: Edit EXIF?
Post by pulancho »
Okay, I did that. In Edit Metadata I clicked on Clear all. Then I added only EXIF:Make and set it to Canon. But when I look at the photo in the full view the EXIF still says SONY ILCE-6700.
Re: Edit EXIF?
pulancho wrote: Thu Jul 03, 2025 1:58 am Okay, I did that. In Edit Metadata I clicked on Clear all. Then I added only EXIF:Make and set it to Canon. But when I look at the photo in the full view the EXIF still says SONY ILCE-6700.
in Viewer in Properties>EXIF tab?
reload file (ctrl+r)
Re: Edit EXIF?
are you in browser?
pulancho
Re: Edit EXIF?
Post by pulancho »
In the viewer I tried reload, but it still shows Sony.
Re: Edit EXIF?
pulancho wrote: Fri Jul 04, 2025 7:30 am In the viewer I tried reload, but it still shows Sony.
please try in brwoser
pulancho
Re: Edit EXIF?
Post by pulancho »
I did CMD+R in the browser, but it didn't seem to do anything. I then opened the photo into the viewer again and it still shows Sony.
Re: Edit EXIF?
pulancho wrote: Mon Jul 07, 2025 8:35 am I did CMD+R in the browser, but it didn't seem to do anything. I then opened the photo into the viewer again and it still shows Sony.
press F5 in Browser to refresh
also, you can record screencast to illustrate your issue
pulancho
Re: Edit EXIF?
Post by pulancho »
When I press F5 a MacOS message comes up asking if I want to enable Dictation?
