1.9.1: “Convert to series” alters the characteristics of photos without any ‘action’ selection selected
Re: 1.9.1: “Convert to series” alters the characteristics of photos without any ‘action’ selection selected
so your screenshot looks correct, you use 'embedded image' for viewing, and 'full size' for convert
massimo.peca
So, why do I see the altered file, as before?
the issue with not respecting Convert setting is fixed
so you can change 2 comboboxes (and rendering options) to whatever you need:
ps. you know that Camera RAW files (NEF, CR2, DNG, etc.) usually contain embedded JPEG (for fast preview) in addition to RAW data, right?user0 wrote: Fri Jun 06, 2025 4:26 pm check 'Camera RAW' settings in Settings>Formats>Read
by default, its:
- for Viewing
- Embedded preview (JPEG)
- for Converting
- Full size
- some adjustments from 'Full/Half size rendering group'
massimo.peca
Yes. Look...user0 wrote: Thu Oct 02, 2025 3:01 pm you know that Camera RAW files (NEF, CR2, DNG, etc.) usually contain embedded JPEG (for fast preview) in addition to RAW data, right?
That seems right to me. Right?
it's up to you; you can use any of the sources:
- jpeg preview OR
- raw image data (and adjust colors yourself)
if jpeg preview looks right - use it
massimo.peca
I prefer the RAW file.
Thanks.
Thanks.
