Failed to convert to avif format
phars
Re: Failed to convert to avif format
Post by phars »
What did you mean by installing libheif-plugin?
Did you mean installing it in
/opt/XnConvert/Plugins
or installing it on my device as a whole?
I notice that there are libraries in the plugins file and I think that they are libraries for converting image formats.
Do you mean install libheif-plugin there?
phars wrote: Wed Aug 20, 2025 9:23 am What did you mean by installing libheif-plugin?
no with
apt install libheif-plugin*
phars
Post by phars »
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
Note, selecting 'libheif-plugin-svtenc' for glob 'libheif-plugin*'
Note, selecting 'libheif-plugin-libde265' for glob 'libheif-plugin*'
Note, selecting 'libheif-plugin-rav1e' for glob 'libheif-plugin*'
Note, selecting 'libheif-plugin-aomdec' for glob 'libheif-plugin*'
Note, selecting 'libheif-plugin-x265' for glob 'libheif-plugin*'
Note, selecting 'libheif-plugin-aomenc' for glob 'libheif-plugin*'
Note, selecting 'libheif-plugin-j2kdec' for glob 'libheif-plugin*'
Note, selecting 'libheif-plugin-j2kenc' for glob 'libheif-plugin*'
Note, selecting 'libheif-plugin-dav1d' for glob 'libheif-plugin*'
Note, selecting 'libheif-plugin-jpegdec' for glob 'libheif-plugin*'
Note, selecting 'libheif-plugin-jpegenc' for glob 'libheif-plugin*'
Note, selecting 'libheif-plugin-ffmpegdec' for glob 'libheif-plugin*'
libheif-plugin-aomdec is already the newest version (1.19.8-1~ppa1~ubuntu24.04).
libheif-plugin-libde265 is already the newest version (1.19.8-1~ppa1~ubuntu24.04).
libheif-plugin-x265 is already the newest version (1.19.8-1~ppa1~ubuntu24.04).
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
libheif-plugin-rav1e : Depends: libheif1 (= 1.17.6-1ubuntu4.1) but 1.19.8-1~ppa1~ubuntu24.04 is to be installed
E: Unable to correct problems, you have held broken packages.
phars
Post by phars »
Does XnConvert need a newer version of libheif-plugin or a specific version? :?:
phars wrote: Mon Aug 25, 2025 11:18 am Does XnConvert need a newer version of libheif-plugin or a specific version? :?:
on Mint 22, i have installed
, and XnConvert works correctly to write AVIF
phars
Post by phars »
but he sends this to me
here is what is installed
libheif-dev/noble-updates,noble-security 1.17.6-1ubuntu4.1 amd64
libheif-examples/noble-updates,noble-security 1.17.6-1ubuntu4.1 amd64
libheif-plugin-aomdec/noble-updates,noble-security,now 1.17.6-1ubuntu4.1 amd64  [installé]
libheif-plugin-aomenc/noble-updates,noble-security,now 1.17.6-1ubuntu4.1 amd64  [installé]
libheif-plugin-dav1d/noble-updates,noble-security,now 1.17.6-1ubuntu4.1 amd64  [installé]
libheif-plugin-ffmpegdec/noble-updates,noble-security,now 1.17.6-1ubuntu4.1 amd64  [installé]
libheif-plugin-j2kdec/noble-updates,noble-security,now 1.17.6-1ubuntu4.1 amd64  [installé]
libheif-plugin-j2kenc/noble-updates,noble-security,now 1.17.6-1ubuntu4.1 amd64  [installé]
libheif-plugin-jpegdec/noble-updates,noble-security,now 1.17.6-1ubuntu4.1 amd64  [installé]
libheif-plugin-jpegenc/noble-updates,noble-security,now 1.17.6-1ubuntu4.1 amd64  [installé]
libheif-plugin-libde265/noble-updates,noble-security,now 1.17.6-1ubuntu4.1 amd64  [installé]
libheif-plugin-rav1e/noble-updates,noble-security,now 1.17.6-1ubuntu4.1 amd64  [installé]
libheif-plugin-svtenc/noble-updates,noble-security,now 1.17.6-1ubuntu4.1 amd64  [installé]
libheif-plugin-x265/noble-updates,noble-security,now 1.17.6-1ubuntu4.1 amd64  [installé]
libheif1/noble-updates,noble-security,now 1.17.6-1ubuntu4.1 amd64  [installé]
phars
Post by phars »
Thank you, it worked. :D
