Crashes on video
Re: Crashes on video
biley wrote: Thu Feb 19, 2026 7:34 am Please let me know if you would like me to test anything.
do you have tried to set
QT_XCB_GL_INTEGRATION=xcb_egl
biley
Post by biley »
xnview wrote: Thu Feb 19, 2026 7:57 am
When I launch the program with "QT_XCB_GL_INTEGRATION=xcb_egl xnviewmp" - I still get the same crashes.
Latest log is attached.
biley
Post by biley »
1.10.1 still crashes on videos for me, both with and without xcb_egl being set. Logs are attached. With this version, it doesn't get to the sound playing, the program just terminates immediately when a video is run.
1.9.2 still works at playing videos. 1.9.2 does have a graphical glitch in the areas where the xnviewmp window is larger than the video being displayed. I get a weird 'echo' of past images/videos or underlying windows. It is just a cosmetic glitch, but it may be relevant to tracking down why videos are causing crashes in later versions.
argumon
Post by argumon »
I also have crashes on any video I tried, Manjaro KDE.
Command line output is
0.35.0 (git 2dd615b) - Multimedia Development Kit. Copyright (c) 2016-2025 WangBin(QtAV author) <wbsecg1 at gmail.com>
Build for: manjaro/ 6.19.2-1-MANJARO 4KB x86_64; glibc2.24/2.43 libc++220000; Clang22.0.0 (++20250929081746+eef7a7663d27-1~exp1~20250929201945.1197); 03:47:23 Sep 30 2025.
==> 2,000000  2,000000  125,864833  96,000000  (1)
XNVIEW restoreGeometry before : 640 480
XNVIEW restoreGeometry after : 850 620
ARG[] = /home/arne/bin/XnView/XnView
qt.gui.icc: fromIccProfile: failed minimal tag size sanity
QPngHandler: Failed to parse ICC profile
QObject::connect: No such signal InfoPropertiesView::itemDoubleClicked(QTreeWidgetItem*,int)
QCssParser::parseColorValue: Specified color without alpha value but alpha given: 'rgb 0, 0, 0, 127'
QCssParser::parseColorValue: Specified color without alpha value but alpha given: 'rgb 255, 255, 255, 255'
## updateCount ===>   12ms
## updateCount ===>   12ms ok
## updateCount ===>   3ms
## updateCount ===>   3ms ok
IPTC GET <IMG-20241220-WA0000.jpg>
X11 display: 0x1ef11610
QMDKWidget setMedia /mnt/data/Users/Public/Videos/Tanzen/1 SW/2010-06-11 SW.mp4
QMDKWidget play
resizeGL>>>>>dpr: 2.000000, logical dpi: (96.000000,96.000000), phy dpi: (125.674783,126.054884)
zsh: segmentation fault (core dumped)  ./xnview.sh
Setting QT_XCB_GL_INTEGRATION=xcb_egl does not help
biley wrote: Sat Feb 28, 2026 12:33 am 1.10.1 still crashes on videos for me, both with and without xcb_egl being set. Logs are attached. With this version, it doesn't get to the sound playing, the program just terminates immediately when a video is run.
you have the crash after the line "#MDK SDK : 0x7f5588018470mdk::NativeVideoBufferPool::Nat"??
argumon wrote: Sun Mar 01, 2026 10:23 am I also have crashes on any video I tried, Manjaro KDE.
Please enable debug=2 in your xnview.ini and send me the logs
biley
Post by biley »
xnview wrote: Sun Mar 01, 2026 2:18 pm
Yes, that is where the log ends, because the program has crashed and terminated.
biley wrote: Sun Mar 01, 2026 11:27 pm Yes, that is where the log ends, because the program has crashed and terminated.
ok, i contact author of video engine
revadiaz
Post by revadiaz »
any update on this problem? still crashes in cachyos.
