XnView MP 1.9.6
XnView MP 1.9.6
You can download XnView MP 1.9.6 here:
Windows
  Package   Architecture SHA256
ZIP x64 2F12B312FCC1D95366B6BFCB1A77ED740D84B01639922D39387B505424BC8474
SETUP x64 E0B2B3A6975E5E1F7E2819AA8BFE2E2CADBE9498C1E68B5947681FF8EC4B42A9
Mac
DMG x64 58E5CD08E6251CED1E2D0ACD99413D8E82B6610A7DBED05BCF53E6CFE01B6BE8
Linux
TGZ x64 2DF628295CAB203020FE092CE06E6D3090942495F941227EEEB627A9C584FFBC
DEB x64 111C7ABC31D86F6F4BEFCF5A76408FB8D159EA55FF99AEDBEA9F95FE0B33A948
AppImage x64
Flatpak x64
ARM
TGZ arm64
Changelog
3805: [New] MDK 0.35.0
3794: [New] Search - Group
3789: [New] Albums as tree
3780: [New] Smart Album
3804: [New] All ExifTool Metadata can be stored in catalog
3804: [Bug] update metadatas - base path - viewtopic.php?t=49866
3803: [Bug] Detail column + thumbnails label - Lens Model
3802: [Bug] Browser - thumbnails - issue with thumbnails generation - viewtopic.php?t=49863
3801: [Bug] Filter by color label - refresh show no files
3800: [Bug] Panel - copy value - extra tab
3799: [Bug] Show files in subfolders - Shortcut
3798: [Bug] Paste in selection - viewtopic.php?t=49836
3797: [Bug] Browser - filelist - Copy should not be default action - viewtopic.php?f=60&t=44891
3796: [Bug] Minor Bug in Viewer - Info Pane - viewtopic.php?t=49837
3795: [Bug] Browser - filelist - Move should not Copy files - viewtopic.php?f=60&t=44892
3793: [Bug] JPEG-li must be loaded with RGB profile - viewtopic.php?t=49827
3792: [Bug] RGB adjust - viewtopic.php?t=49830
3791: [Bug] MacOS - Heic - libheic updated - viewtopic.php?t=49821
3790: [Bug] DNG orientation broken after cropping image - viewtopic.php?t=49771
3788: [Bug] Browser - catalog filter - add Square orientation, fix sorting - viewtopic.php?t=49725
3787: [Bug] Settings - Integration - add 'Enable XnShell' checkbox - viewtopic.php?t=49749
3786: [Bug] Settings - Integration - improve UAC elevation handling - viewtopic.php?t=49783
3785: [Bug] Browser - thumbnails - overlay icon - do not hide when dropdown appears - viewtopic.php?t=49811
3784: [Bug] Info is not updated in multiselect - viewtopic.php?t=49480
3783: [Bug] afphoto
3782: [Bug] Grey 8 - antialiasing - viewtopic.php?t=49797
3781: [Bug] Text opacity not persistent in drawing mode - viewtopic.php?t=49809
3779: [Bug] Info - Color model - RGB shown for Greyscale psd
3778: [Bug] Search city in Iptc4xmpCore - viewtopic.php?t=49762
3777: [Bug] Change timestamp incorrectly modifies data in movie files - viewtopic.php?t=49786
3776: [Bug] Renaming a folder shouldn't attempt to split ext - viewtopic.php?t=49748
3775: [Bug] ghostscript 10.06 - viewtopic.php?t=49772
3774: [Bug] Info not updated - viewtopic.php?t=49777
3773: [Bug] Open with in context menu for video file - viewtopic.php?t=49356
3772: [Bug] Video link doesnt play
3771: [Bug] EXIF data in AVIF files generated with avifenc is not displayed - viewtopic.php?t=49709
3770: [Bug] Viewer - properties - Favorites - tab does not memorize tags - viewtopic.php?t=49737
3769: [Bug] Browser - info - favorites - always show all added tags - viewtopic.php?t=49644
3768: [Bug] xmp keywords insert order - viewtopic.php?t=49662
3767: [Bug] Encoding in preview of .xmp - viewtopic.php?t=49720
3766: [Bug] Histogram not updated
3765: [Bug] Edit metadata - Exif image description missing
