Batch rename not saving empty value
FKCapitalism2
When using batch rename (F2) on multiple files and i set value in With field to empty (sometimes i want to use empty to remove existing value) it does not save after renaming and opening dialog again (F2) With field still has old value.
- Attachments
- 1.jpg (39.69 KiB) Viewed 82 times
Re: Batch rename not saving empty value
