The problem is reproduced [MP v1.9.8] as follows:
1) Double-click the image to enter editing mode.
2) After cropping the image, press the browse icon in the upper left corner to exit.
3) The image does not update.
4) Even pressing F5 to update fails.
Only re-entering editing mode and pressing Esc to exit restores normal updating.
Unable to update images after cropping
Re: Unable to update images after cropping
you need to save image after cropping in Viewer
Yes, the first time you edit, it will ask if you want to save with a preset, and the next time it will set it to save automatically, but this problem occurs on the second time or later.
you must have checked 'Don't ask again' checkbox in 'Confirm save' dialog and pressed No
press 'Reset all confirm prompts' in Settings>General
I've already tried it, but it didn't work.user0 wrote: Sun Jan 11, 2026 9:43 am you must have checked 'Don't ask again' checkbox in 'Confirm save' dialog and pressed No
It works fine if I press Esc to exit editing instead of the browse icon, which clearly indicates a bug.
