Batch Convert Suggestion: Multiple saves/version for same file
XnSoldier
Re: Batch Convert Suggestion: Multiple saves/version for same file
Post by XnSoldier »
Quite a nice idea as I often create two version of files also. But they would be saved in different subfolders with the different Presets.
I use original filenames and processed files keep the names and get saved in subfolders.
But usage of "Multiple Resolutions" is not self explanatory:
There is an option to open some file but it is not a settings profile I can open. It seems it is a destination folder selection. This should be explained.
Photographer. Sorting 100.000-250.000 pics per year
20 years with ACDSee Photo Professional. Love and Hate. I would love to see XnView MP upgraded for better editing or a commercial "XnPhoto Pro"! Keep up the great work!
jkm
Post by jkm »
XnSoldier wrote: Mon Mar 16, 2026 6:07 pm This should be explained.
It was explained.
Why don’t you read the documentation post that is pinned at the top of this forum?
viewtopic.php?t=50370
Actually, it was explained twice. Because cday asked just a few days ago, before I had time to do the documentation. It’s right there on the first page of this forum, if you look.
viewtopic.php?t=50467
XnSoldier
Post by XnSoldier »
I don't see any sticky post in this thread.
And my point stands: Folder selection should be explained in the dialog box for usability.
jkm
Post by jkm »
XnSoldier wrote: Mon Mar 16, 2026 6:31 pm
I said forum, not thread, and I gave you a link.
If you can’t find it with a link, you just don’t want to. That can’t be helped.
You’re welcome.
