Unable to load database during reinstallation (Misunderstand)
Re: Unable to load database during reinstallation
No, the path of your folder/image files?
Do you have the categories list in Catalog filter panel?
alee001
Post by alee001 »
xnview wrote: Tue May 05, 2026 12:48 pm No, the path of your folder/image files?
The image shows the covered paths and folder contents.
As shown, the category list does not contain the categories I created, and the language display is also incorrect. There are also no rating items created.
alee001 wrote: Tue May 05, 2026 1:30 pm the language display is also incorrect.
what's problem?
I don't understand, i see several .db with different size. Which is the good one, the 50GB one?
In Settings>Catalog, do you see the paths of your folders?
Is it possible to have the .db?
alee001
Post by alee001 »
xnview wrote: Tue May 05, 2026 2:09 pm
what's problem?
I'm very sorry everyone. I've finally figured out what caused the database to be invalid. It turns out that the copy and restore script provided by AI I used earlier had an error. Now, after deleting the entire folder and manually copying the backup, I can restore the database.
I apologize for any inconvenience this may have caused.
