WinRAR 3.70 beta 4 has been Released!
Change Log:
1. New "Request administrative access" option in "Advanced" page
of "Advanced SFX options" allows to create SFX archive,
which will request the administrative access when started
in Windows Vista.
Command line equivalent of this option is -iadm switch.
2. Correction in DBCS encoding (Japanese, Chinese, etc.) support
in WinRAR shell extension for Windows 9x/Me.
3. Corrected a bug in extracting files from UDF ISO images
exceeding 4 GB.
Version 3.70 beta 3
1. It is possible to set the string value "AppData" in Registry key
HKEY_CURRENT_USER\Software\WinRAR\Paths to override the default
%appdata%\WinRAR path for WinRAR settings.
For example, if you wish to store theme files in WinRAR folder,
set this value to "c:\Program Files\WinRAR".
2. Total progress bar is displayed when unpacking UDF ISO files.
3. In previous versions archive icons were not changed when selecting
a new WinRAR theme in Windows Vista.
4. WinRAR displays a warning if resulting archive is self-extracting
and archive size exceeds 4 GB. Windows cannot run executables
of such size.
5. Corrections in ISO processing code.
Version 3.70 beta 2
1. Positions of "Mode" and "Cancel" buttons in archiving dialog
have been exchanged.
2. Bugs corrected:
a) beta 1 could truncate names of files decompressed from ISO 9660
archives by one character;
b) progress bars in archive conversion window did not work correctly
with "Windows progress bars" option turned on;
c) "Load WinRAR settings from" dialog did not displayed if
settings.reg was not present in %appdata%\WinRAR folder.
Compression apps
ckit
ckit
WinRAR 3.70 beta 7 has been Released!
Change Log:
1. Bugs corrected:
a) -ioff switch did not work in unrar.exe;
b) WinRAR 3.70 beta failed to process volumes with malformed
file name extensions like .rar, .002, .r03. It continued to
ask for next volume even after specifying its exact name;
c) WinRAR shell extension did not work in Windows 95.
Change Log:
1. Bugs corrected:
ckit
WinRAR 3.70 beta 8 has been Released!
Change Log:
1. Bugs corrected:
a) WinRAR shell extension did not work in Windows NT 4.0;
b) when unpacking ZIP archives in command line mode WinRAR
returned "write error" (numeric 5) code in situations
when it should return "create error" (numeric 9).
Download: http://www.rarlab.com/rar/wrar37b8.exe
Homepage: http://www.rarlab.com/
I may go a little nuts if there is a beta 9
Change Log:
1. Bugs corrected:
ckit
WinRAR 3.70 Final has been Released!
Change Log:
1. Numerous Windows Vista compatibility changes:
a) help format changed from old HLP to newer HTML based CHM;
b) GUI self-extracting modules attempt to request for
administrator permissions if they cannot create destination
folder under current user account;
c) Log file rar.log and WinRAR theme files are stored
in %APPDATA%\WinRAR folder instead of WinRAR program files folder.
Exported settings file settings.reg is also stored
in %APPDATA%\WinRAR folder by default, but it is possible to
select another folder in "Save WinRAR settings" and "Load WinRAR
settings" dialogs.
WinRAR searches for registration key and settings.reg
both in its program files folder and in %APPDATA%\WinRAR;
d) Vista compatibility changes in WinRAR shell integration;
e) New "Request administrative access" option in "Advanced" page
in Windows Vista.
2. Added support for ISO 13346 (UDF) file format. This format
is frequently used in ISO images of DVD disks.
3. Added Unicode support for ISO 9660 files, so WinRAR should
handle non-English file names in .iso files better.
4. Design changes in window displaying archiving and extraction
progress:
a) it provides more space for file names, allowing lengthy names;
b) it displays the current archive name in separate line,
allowing much longer archive names than before;
c) when archiving, it displays the current compression ratio
in separate line;
d) it can use both standard Windows and classic WinRAR progress bars.
Turn on "Windows progress bars" option in WinRAR "Settings/General"
dialog to use standard progress bars. By default this option is
on if some Windows visual style is active and off if Windows Classic
theme is selected.
Windows progress bars are two color only, so they do not indicate
the current compression ratio. But now the ratio is displayed
in separate line;
e) "Mode..." button moved to bottom of window.
5. GUI self-extracting modules support following command line
switches:
-d set the destination path
-p specify a password
-s silent mode, hide all
-s1 same as -s
-s2 silent mode, hide start dialog
-sp specify parameters for setup program
6. GUI self-extracting modules do not pass the entire command line
to setup program like they did in previous versions.
If you need to get access to entire command line of SFX archive,
parse sfxcmd environment variable which contains this command line.
7. New switch -sc[objects] allowing to select character
sets for archive comments and list files. It replaces -fcu switch
introduced in RAR 3.60, which was removed from list of supported
switches. Now you need to specify -scuc instead of -fcu to use
Unicode comments. Unlike -fcu, -sc also supports OEM and ANSI charset.
8. New "Save archive copy as..." command in "File" menu.
This command may be useful if you opened an archive from Internet
directly in WinRAR and then decided to save it on local disk.
9. "Word wrap" command added to "View" menu of WinRAR internal viewer,
so you can change the wrapping mode of already opened viewer window.
State of this option is not stored between viewing sessions.
If you need to change the default word wrap mode, use WinRAR
"Settings/Viewer" dialog.
10. Buttons "Up" and "Down" added to "Organize profiles" dialog.
Using these buttons you can change position of selected profile
in the list.
11. Operation progress is displayed when adding the recovery record.
12. If WinRAR is minimized to tray and mouse is over its icon,
WinRAR diplays a message about the current operation progress.
In previous versions it included only percent done, now it also
contains the time left information.
13. Console RAR displays "Calculating the control sum" message
when calculating CRC32 control sum for newly created RAR volume.
Previous versions also calculated the volume control sum,
but did it silently.
14. Archives history list in "File" menu allows Unicode names,
providing more reliable support for non-English archive names.
15. Stack overflow vulnerability has been corrected in password
processing module of console RAR and UnRAR. GUI WinRAR is not
affected. We are thankful to the iDEFENSE LABS for reporting this bug.
Download: http://www.rarlab.com/rar/wrar370.exe
Change Log:
settings" dialogs.
in Windows Vista.
progress:
in separate line;
theme is selected.
in separate line;
switches:
-s1 same as -s
in the list.
ckit
WinRAR 3.71 Released!
1. Archive names in rar.log error log file always include
the full path.
2. WinRAR tray icon is compatible with high DPI display modes.
3. If you modified a file in archive with encrypted names using
an external editor, WinRAR will not ask for archive password again
when prompting to update a file. It will use a password which
you entered when opening an archive,
4. Bugs fixed:
a) switch -tl and "Set archive time to latest file time" option
could fail in previous version. Sometimes they set archive time
to current system time instead of latest file time;
b) if -ag switch mask contained archive number, month and minute
characters, WinRAR placed 'I' character instead of minute value
into generated archive name for archive numbers exceeding 1;
c) high ASCII names in ISO files using ISO 9660 format without
Joliet format extension were displayed incorrectly;
d) WinRAR could crash when decompressing some of corrupt RAR archives;
e) if "Turn PC off when done" option was set in "Convert archives"
command, WinRAR turned PC off after converting the first archive
in selected group instead of after converting the entire group;
f) if user specified a non-existent destination path in SFX archive
in Vista, SFX could enter into infinite "create new SFX window"
loop;
g) WinRAR could fail to unpack an individual file from subfolder
of ACE archive using the drag and drop.
Download: http://www.rarlab.com/download.htm
the full path.
4. Bugs fixed:
loop;
marsh
7-Zip 4.57 (2007-12-06) for Windows has been released!
Homepage: http://www.7-zip.org/
Virtual_ManPL
PowerArchiver 2007
I use PowerArchiver 2007 10.21.17 xD
@ckit
stop spamming with new releases xP
@ckit
Re: PowerArchiver 2007
It's a good idea to split the "new version" info from this thread, Virtual_ManPL. A friendlier tone would be appreciated, though. Thanks!Virtual_ManPL wrote:..
@ckit
