Philippe
Posts: 3 Joined: Wed Apr 28, 2004 11:27 am
Post
by Philippe » Wed Apr 28, 2004 8:32 pm
Hello!
This is how I managed the EXIT in my file
gflGetDefaultLoadParams(LoadParam);
LoadParam.Flags := GFL_LOAD_METADATA;
Erreur := gflLoadBitmap(NomFichier, GFLImage, LoadParam, InformationFichier);
if GFLBitmapHasEXIF(GFLImage) = GFL_True then
Exif := gflBitmapGetEXIF(GFLImage, EXIF_MAIN_IFD);
However I have the following error message "incorrect floating point operation" when I execute the function gflBitmapGetEXIF
the structure of EXIF is
const
EXIF_MAIN_IFD = $0001;
EXIF_IFD_0 = $0002;
EXIF_INTEROPERABILITY_IFD = $0004;
EXIF_IFD_THUMBNAIL = $0008;
EXIF_GPS_IFD = $0010;
EXIF_MAKERNOTE_IFD = $0020;
type
TGFL_EXIF_ENTRY = record
Flag : GFL_UINT32; // EXIF_...IFD
Tag : GFL_UINT32;
Value : PCHAR;
end;
PGFL_EXIF_ENTRY = ^TGFL_EXIF_ENTRY;
type
TTabGFL_EXIF_ENTRY = array [0..0] of TGFL_EXIF_ENTRY;
PTTabGFL_EXIF_ENTRY = ^TTabGFL_EXIF_ENTRY;
TGFL_EXIF_DATA = record
NumberOfItems : GFL_UINT32;
ItemsList : PTTabGFL_EXIF_ENTRY; //PGFL_EXIF_ENTRY;
end;
PGFL_EXIF_DATA = ^TGFL_EXIF_DATA;
The problem does not occur everytime I open a picture
Any ideas?
Posts: 49080 Joined: Mon Oct 13, 2003 7:31 am
Post
by xnview » Thu Apr 29, 2004 4:43 am
Philippe wrote: This is how I managed the EXIT in my file
Seems to be correct!
You have the problem on all picture with EXIF data?
Philippe
Post
by Philippe » Thu Apr 29, 2004 9:38 pm
not, much of photographs do not have the problem
Post
by Guest » Tue May 04, 2004 2:45 pm
Moreover, with these photographs, I cannot use the functions GFLResize or GFLRotate. I have an error "Error to create file" on the GFLSaveBitmap function.
Does somebody have an idea?
Post
by xnview » Thu May 13, 2004 3:06 pm
Anonymous wrote: Moreover, with these photographs, I cannot use the functions GFLResize or GFLRotate. I have an error "Error to create file" on the GFLSaveBitmap function.
Could you tell me more about these photos? Or send me example?
Kobby
Posts: 2 Joined: Fri Nov 10, 2006 2:26 pm
Post
by Kobby » Fri Nov 10, 2006 2:37 pm
Same problem. I use VC.Net with a similar code:
GFL_LOAD_PARAMS params;
GFL_BITMAP gflBitmap;
GFL_BITMAP *pgflBitmap = &gflBitmap;
GFL_ERROR error;
gflGetDefaultLoadParams(¶ms);
error = gflLoadBitmap(strFileName, &pgflBitmap, ¶ms, NULL);
if (error == GFL_NO_ERROR)
if( gflBitmapHasEXIF(pgflBitmap))
GFL_EXIF_DATA *pEXIF = gflBitmapGetEXIF(pgflBitmap, 0);
for (int i = 0; i<pEXIF>NumberOfItems; i++)
ATLTRACE2( atlTraceGeneral, 4,"%s\t%s\r\n",pEXIF->ItemsList[i].Name,pEXIF->ItemsList[i].Value);
I always get an access violation error on the gflBitmapHasEXIF.
Any thoughts?
Kobby
Post
by Kobby » Fri Nov 10, 2006 2:51 pm
Ops,
I just did not swich on flage GFL_LOAD_METADATA.
It works fine now.
