I am converting tiff files (with the sRGB colorspace) to thumbnail size. To verify the color space of the thumbnail I'm looking in Photoshop. Photoshop says no color space is associated.
I am using the -keepcspace parameter. I have got it to work with *.jpeg files. What's the reason it doesn't work with the tiff format?
Thanks alot.
Justin
NConvert & Color Spaces
Re: NConvert & Color Spaces
Currently only jpeg can be saved in CMYKjustinjtownsend wrote:I am converting tiff files (with the sRGB colorspace) to thumbnail size. To verify the color space of the thumbnail I'm looking in Photoshop. Photoshop says no color space is associated.
tmaes
another question about this...
I tried to convert an image from rgb to cmyk using -ctype option,
I tried on a tiff and, after I saw your last remark, on a jpeg, in the second case it created 2 copies of the jpeg, but in the properties box of these new images(in xnview), the color range is still RGB is it normal of am I wrong somewhere?
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\tmaes>"c:\Program Files\XnView\nconvert.exe" -ctype cm
yk "c:\Documents and Settings\tmaes\Desktop\99.tif"
** NCONVERT v4.81 (c) 1991-2007 Pierre-E Gougelet (Aug 13 2007/14:38:42) **
Version for Windows NT/9x/2000/Xp/Vista (All rights reserved)
** This is a freeware software (for non commercial use)
Conversion of c:\Documents and Settings\tmaes\Desktop\99.tif into c:\Documents a
nd Settings\tmaes\Desktop\99.tif OK
yk "c:\Documents and Settings\tmaes\Desktop\99.jpg"
Conversion of c:\Documents and Settings\tmaes\Desktop\99.jpg into c:\Documents a
nd Settings\tmaes\Desktop\99.jpg OK
C:\Documents and Settings\tmaes>-
Re: another question about this...
ctype is only used for RAW formattmaes wrote:I tried to convert an image from rgb to cmyk using -ctype option,
