Export from Multiple convert Script (.xbs) into nconvert batch file (in the multiple convert dialog )loose the -rflag option, i.e. the option is present in the .xbs, but not in the exported command line in the batch
version is 1.82.4, WINXP
BTW: JPEG quality default to 100 in nconvert is not very wise, i think it shoul default to 85, as usual in other apps
Script Export Bug
Re: Script Export Bug
Ok, i'll checkRajko Aust wrote:Export from Multiple convert Script (.xbs) into nconvert batch file (in the multiple convert dialog )loose the -rflag option, i.e. the option is present in the .xbs, but not in the exported command line in the batch
