Browser -> doubleclick -> Viewer fullscreen = slow
stax
Post by stax »
it's slow because of the MDI menu update, any way to show it instantly? I think it would make look a professional application look even more professional.
Re: Browser -> doubleclick -> Viewer fullscreen = slow
stax wrote:it's slow because of the MDI menu update, any way to show it instantly? I think it would make look a professional application look even more professional.
I can't reproduce your problem, but this might have various reasons (settings, performance,...).
Some questions to shed more light into this:
- Could you please describe your settings and your steps when opening the image in some more detail?
- How long does it roughly take to open the fullscreen on your system?
- What computer hardware do you use?
stax
Post by stax »
when I double click in the browser on a thumbnail I configured the application to display the image as fullscreen but before you see how the main menu gets updated because a different document type is loaded. Are you the programmer othe application? You know about the MFC MDI architecture?
stax wrote:When I double click in the browser on a thumbnail I configured the application to display the image as fullscreen but before you see how the main menu gets updated because a different document type is loaded. Are you the programmer othe application? You know about the MFC MDI architecture?
I've just tried this, but the fullscreen appears instantly. I work on a P4 with 2.4 GHz and a ATI Radeon 9200, so probably no wonder.
Just to make sure: Could you please temporarily rename your xnview.ini, then start XnView and set the setting "View in fullscreen" (in Options, category "Browser") and then try again?
stax wrote:Are you the programmer othe application? You know about the MFC MDI architecture?
Pierre is the programmer of XnView.
stax
Post by stax »
done it with the same result, I've got a Athlon 2200+ with a possibly slow graphics system. It's only a glimpse but it's clearly noticeable the menu get updated
stax wrote:when I double click in the browser on a thumbnail I configured the application to display the image as fullscreen but before you see how the main menu gets updated because a different document type is loaded.
Strange, i have not theproblem!
Why you ask this question about MFC MDI? XnView is not based on MFC!
stax
Post by stax »
when I switch from the browser mdi child to a image mdi child I get another different main menu. When I double click on a thumbnail in the browser I see the mdi child in fullscreen but before I see clearly how the main menu gets updated instead of seeing the fullscreen image instantly. Another cosmetic thing that makes the application look a little bit slow is when you single click a thumbnail you see how the mouse curser changes.
I thought it's a MFC app, wxWindows?[/quote]
stax wrote:when I switch from the browser mdi child to a image mdi child I get another different main menu. When I double click on a thumbnail in the browser I see the mdi child in fullscreen but before I see clearly how the main menu gets updated instead of seeing the fullscreen image instantly.
Very strange....
The cursor is changed in a wait cursor...
No, win32 app
Keyzer
Post by Keyzer »
It happens when I sort by file type
Keyzer wrote:It happens when I sort by file type
Even with sorting by file type, i have no delay when i open the picture!
Keyzer
Post by Keyzer »
Did you try it in a folder with 30+ pictures. Look at the pic. It's in a folder with over 700 in it.
http://home.broadpark.no/~krjgutto/cpu-hog.jpg
