Fit in, Fit over
Dreamer
Fit in, Fit over
Post by Dreamer »
So many "Auto image size" options, just 1 I need is still missing
I mean "Touch window from outside" option from MPC, perhaps ckit could explain it better, I want just get rid of black bars - horizontal or vertical, not just horizontal / just vertical.
Edit:
Existing features (only hotkeys suggestions):
- Fit width - Numpad 1
- Fit height - Numpad 3
New features (suggestions):
- Fit width and height ( = fit in) - Numpad 7
- Fit width or height ( = fit over) - Numpad 9
Why Numpad numbers? They are near other "fit image" keys Numpad / and * and also + / -, other numbers move large images, so all Numpad keys would be to move/zoom/fit image.
These options could be also saved on xnview exit.
XnView 1.90 <x>
Dreamer
ckit
Post by ckit »
I use "Touch window from Inside" with a 800x600 MPC window.
While I have a interest in digital video, I'm far from giving advice :)
Dreamer
Post by Dreamer »
OK... 4:3 AR (aspect ratio) - standard for most CRT monitors is OK, but new LCD monitors with ARs 5:4 or 16:10 have very thin black bars (e.g. all 4:3 images have thin strips on 5:4 LCDs), so it would be useful to have a picture at whole screen - those thin strips are not so important.
Since we have 4 similar options, I think this is at least as important / useful - and perhaps not so hard to implement, since just options "Fit to window width" and "Fit to window height" need to be "merged" (somehow), but I could be wrong, Pierre?
Dreamer
Olivier_G
Post by Olivier_G »
I support it.
In my suggestion about Image size, it's called "Fit over".
Olivier
Dreamer
Post by Dreamer »
OK, if it will be added, then another suggestion:
- Shortcut - Shift+Numpad / (or Numpad 7, if it's free, then also Num 1 and Num 3 could be used for 2 existing options - Fit to width/height)
Dreamer
Dreamer
Post by Dreamer »
Olivier_G wrote:I support it.
No, I mean "no black bars", so it's:
So we could change this request (I'll also edit first post):
Dreamer
Olivier_G
Post by Olivier_G »
Dreamer wrote:
Olivier_G wrote:In my suggestion about Image size, it's called "Fit over".
No, I mean "no black bars", so it's: Fit width or height ( = fit over)
I don't follow you... :?
foxyshadis
Post by foxyshadis »
Another way to put it is "crop until no borders are left", or until aspect ratio matches the screen. It's not really a crop, since you ban still scroll around it. Instead of using the first edge that meets the border, like now, you use the other.
Wouldn't have much use for it myself, but hey, if others want it...
Danny
Post by Danny »
What he means is pretty much: stretch or shrink the image until it fits the whole screen without changing it's proportions.
I have no use for this. I would prefer less Auto-Image-Size options since the current amount is already confusing enough. But that's just me.
Get the bugs fixed, THEN start adding features. It sucks, but someone has to do it.
Dreamer
Post by Dreamer »
As I said, there are just very thin borders on some images if you have monitor with 5:4 or 16:10 AR (most of new LCDs), so this option would "zoom" image just a little bit. Or if you watch 4:3 images on wide 16:9 TV, there are borders on all images, this option would help also here...
Dreamer
foxyshadis
I'd probably only use something like this with the occasional verrry long image, like Space Lane or tutorials like this (1200x30000, may crash browser!), although those particular ones are close enough to my resolution that living with a small border/crop is okay. Filmstrips like these are the only place I can see it being really useful.
Olivier_G
Post by Olivier_G »
I would use it quite often:
- to read/check very long horizontal/vertical documents, like Panorama, Comics/Texts...
- to check my photographs (cropped in different ratios) in large size without having to deal with X+Y panning like at 100%.
etc...
Dreamer, when I said "I don't follow you" it wasn't about understanding the feature. It was about understanding why you replied "No" to the parallel I made with "Fit over" in my previous suggestion. I still believe it's the same. Maybe my explanation there is not good, then... :?
Olivier
Dreamer
Post by Dreamer »
I just said I meant "Fit width and height ( = fit in)", not "Fit width or height ( = fit over)", but I'm a bit confused now. Exactly I mean "zoom/crop until no borders are left". Anyway, both options (below) would be useful.
Dreamer
