Enhance resize in Batch Convert
Post by Guest »
Is it possible to add a drop down list for selecting type of fit (when option "keep ratio" is on)?
There is four types of fit that saves ratio:
1. Fit width
2. Fit height
3. Fit width and height ( = fit in)
4. Fit width or height ( = fit over)
Currently, as I see, it is not possible to do fit number 4 in xnView.
This is very usefull when you have a large number of images with different sizes and proportions, that must be set all to one specified size, but with as little cropping as possible. First, one can do "resize - fit over", and than "resize canvas - top center", for instance. I don't see any other way to do this.
Regards,
Ognjen
Re: Enhance resize in Batch Convert
Anonymous wrote:Is it possible to add a drop down list for selecting type of fit (when option "keep ratio" is on)?
1. Fit width
2. Fit height
What is 'Fit W or H'?
Post by Guest »
Ok, examples for everything:
If we want to fit two images sized 200x400 and 400x200 to 100x100 (WxH), keeping the aspect ratio:
1. W: 200x400 -> 100x200;
400x200 -> 100x50
2. H: 200x400 -> 50x100
400x200 -> 200x100
3. W and H: 200x400 -> 50x100
400x200 -> 100x50
4. W or H: 200x400 -> 100x200
400x200 -> 200x100
In other words, "W and H" resize will always produce an image that is smaller or equal to the requested size (or, to be more precise: one dimension will be equal, and other will be smaller) -- that's why it is called "Fit in".
"W or H" will produce an image that is BIGGER or equal to the requested size (one dimnsion is equal, while other is bigger). Thats why it is called "Fit over".
Regards,
Ognjen
Olivier_G
Post by Olivier_G »
Anonymous wrote:"W or H" will produce an image that is BIGGER or equal to the requested size (one dimnsion is equal, while other is bigger). Thats why it is called "Fit over".
I support.
What interface change would be best? (I was thinking of a simple 'Fit over' checkbox that would be ungreyed as soon as both X and Y values are entered...)
Olivier
Anonymous wrote:Ok, examples for everything:
400x200 -> 100x50
400x200 -> 200x100
400x200 -> 100x50
400x200 -> 200x100
Ok, so Fit option replace 'increase only', 'decrease only', and 'switch orientation'?
Olivier_G
Post by Olivier_G »
xnview wrote:Ok, so Fit option replace 'increase only', 'decrease only', and 'switch orientation'?
None. It's a new different option.
If space is an issue, maybe it would be better to put Increase/Decrease on the same line:
Only []Decrease  []Increase
Olivier
Ok, so only a new checkbox 'Fit over'??
Olivier_G
Post by Olivier_G »
I looked at the whole window. Pierre, what do you think of this?
□ Follow orientation (switch W/H)
□ Keep ratio
 o Fit in   o Fit over
□ Decrease  □ Increase
Resample [   |v]
- Shorter name for Orientation
- Fit in/over make sense only with Keep ratio and showing both is more explicit (alternative: only "□ Fit over (W OR H)")
- Show Increase/Decrease actions instead of their exclusive version (ie: only). Both are fine to me, though... :?
- Resample at the end (once the difficult logical choices have been made... :P )
Edit: I put another solution wich looks almost as fine to me and has fewer modifications:
□ Keep ratio
 □ Fit over (W OR H)
Only  □ Decrease  □ Increase
Resample [   |v]
Olivier
Olivier_G wrote:Edit: I put another solution wich looks almost as fine to me and has fewer modifications:
□ Keep ratio
 □ Fit over (W OR H)
Resample [   |v]
So only a new checkbox :-) (and some change)...
Olivier_G
Post by Olivier_G »
xnview wrote:So only a new checkbox :-)
I knew you would prefer this! :mrgreen:
Olivier
Dreamer
Post by Dreamer »
I support this request too, more suggestions (hotkeys):
- Fit width - Numpad 1
- Fit height - Numpad 3
- Fit width and height ( = fit in) - Numpad 7
- Fit width or height ( = fit over) - Numpad 9
More here ("beta topic").
Dreamer
