Could you add an option to shift the location of the info-pane (in the preview)? Now its located to the right, but IMHO it would really fit better in the bottom of the preview-window. I can not make use of it as it works now, which is a shame with all the goodies there.
EDIT: I'm talking about the "properties"-tab, didn't have XnView in front of me when writing the message.
Imageinfo-pane in the bottom
I can't use it like that either, I went and merged everything by double-clicking the space next to the tab icons, now everything is a tab
Re: Imageinfo-pane in the bottom
I support, as already asked here (+removal of 'use tabs').Troken wrote:Could you add an option to shift the location of the info-pane (in the preview)? Now its located to the right, but IMHO it would really fit better in the bottom of the preview-window.
Olivier
