Browser tree expansion
paulba
Post by paulba »
This is hard to explain in text....
when browsing through folders each folder can be expanded by selecting the "+", if there are no more sub folder then there is no "+".
This is correct for local drives but network drives always have a "+" on the folder even when there is no more sub folders.
examples
Local drive ...Image
Network drive ... Image
if there are no sub folders then there should be no indication that there is. At worst the "+" should disappear when the folder is selected and the browser finds there is no more sub folders.
This happens in versions 1.82.4 and 1.90 beta 3.
Thanks
ckit
Post by ckit »
What you are asking might make XnView even slower with UNC paths or mapped drives.
XnView's tree handling should remain the same as Windows Explorer's.
paulba
Post by paulba »
That would mean it worked the same for both local and network drives. Xnview currently does not match windows explorer.
paulba
Post by paulba »
This is still an annoying glitch ..
examples
Windows Explorer... Image
Xnview Browser... Image
is there a chance this will ever be fixed??
Regards,
Paul
paulba wrote: if there are no sub folders then there should be no indication that there is.
Yes, on network i don't check for subfolder, take often long long time
paulba
Post by paulba »
1. Yes this will be changed
2. it wont change due to time??
If 2 the please add an option in ini file to let us make the decision based on our environment.
Thanks
Paul
Ok, i'll add an ini entry for next release
ckv
Post by ckv »
CheckNetFolder doesn't seem to work in 1.95.4 and 1.96 beta. :(
ckv wrote:CheckNetFolder doesn't seem to work in 1.95.4 and 1.96 beta. :(
Yes, CheckNetFolder is no more used since 1.94.2
You have a '+' when no subfolder??
ckv
Post by ckv »
Yes, I always have '+' for network folders on Windows 2000 SP4.
ckv
Re: Browser tree expansion
Post by ckv »
XnView 1.96 changelog wrote:Fixed:
* CheckNetFolder entry - http://newsgroup.xnview.com/viewtopic.php?t=11011
I didn't realize that this was fixed for XnView 1.96 until now. But when I use CheckNetFolder in XnView 1.96 I don't get the '+' on any folder and the folder tree is unusable?? :(
