HTML template - file size
dcakovan
Post by dcakovan »
Is it possible to add #FILESIZE# in KB for html templates... or is there one already?
Thanks.
Re: HTML template - file size
dcakovan wrote:Is it possible to add #FILESIZE# in KB for html templates... or is there one already?
Thanks.
Is added in 1.90 beta as #<FileSize>#
dcakovan
Post by dcakovan »
That did not seam to work.
I edited one of the templates (thumb.html) and had something like
<a><img>#<Filename># #<FileSize>#</a>
Only the file name would show up.
Am I doing something wrong here?
dcakovan wrote:That did not seam to work.
You have tested with 1.90??
dcakovan
Post by dcakovan »
Yes. With the latest beta 5 as well.
dcakovan wrote:Yes. With the latest beta 5 as well.
For me, it works.
For example, i've change in thumb.html
<div>#THUMB_TEXT#</div>
into
<div>#<Filename>#</div>
dcakovan
Post by dcakovan »
Not sure if there was confusion but I was asking about file size. That does not appear.
THUMB_TEXT and Filename seams to be the same. but that is not an issue.
xnview wrote:Is added in 1.90 beta as #<FileSize>#
Does not work for me.
From what I can see the place holder for file size is #<Size># and #<Size KB># (lower/uppercase doesn't matter).
I was about placing a question why there are placeholders with and without < >. But then the answer came to my mind: We have the original placeholders with #name#. In addition to those placeholders all placeholders which can be used for batch renaming (Tools > Batch rename) are available, but for those you have to use the less than and greater than characters <>, e.g. #<size>#.
It's very good that all those placeholders (original ones and the ones used in batch renaming) can be used, but the mixture of placeholders with '#' and with '#<' is not so good. Perhaps in addition to the # notation there could be the #< notation for all original placeholders.
dcakovan wrote:Not sure if there was confusion but I was asking about file size. That does not appear.
Sorry it's #<Size>#
dcakovan
Post by dcakovan »
xnview wrote: Sorry it's #<Size>#
Thanks a lot. This works but it shows in bytes. Is there another command for kilobytes?
dcakovan wrote:Is there another command for kilobytes?
#<Size KB># (see above)
dcakovan
Post by dcakovan »
I am really sorry, I missed.
Thank you very much.
