Major Memory leak
wOLVERINe
Major Memory leak
Post by wOLVERINe »
At times as I browse my reference directory (only jpgs)., XNView just freezes for a few seconds and continues.. Other times it freezes totally and If I popup the Task Manager all of a sudden it uses 1.2GB of virtual memory and Memory Usage goes from 10 MB to 1100MB within 10 seconds.. Neither of these are image specific btw.. It does this randomly on the files.
Also.. During these freezes that 'do' get to continue after a few seconds XNView isn't using any CPU. Which is kind of weird since you would think if it's computing something it should be using a bit of CPU.. Or might this be a I/O problem ? (Don't have this problem with ACDSee Classic)..
Awesome tool btw, it even supports Maya IFF, HDRI and OpenEXR..
Keep up the good work.. I hope you can solve the memory problem.
Cheers,
wOlv.
Re: Major Memory leak
wOLVERINe wrote:At times as I browse my reference directory (only jpgs)., XNView just freezes for a few seconds and continues.. Other times it freezes totally and If I popup the Task Manager all of a sudden it uses 1.2GB of virtual memory and Memory Usage goes from 10 MB to 1100MB within 10 seconds.. Neither of these are image specific btw.. It does this randomly on the files.
You have only JPEG files? Which picture size?
wOLVERINe
Post by wOLVERINe »
Correction.. JPEG and GIF files in the folder (280 files)... nothing else.
The size ranges from 852x576 to 1075x1708..
Cheers,
wOLv.
wOLVERINe wrote:Correction.. JPEG and GIF files in the folder (280 files)... nothing else.
And if you try only jpeg?
wOLVERINe
Post by wOLVERINe »
Does it with jpegs only... I haven't had this with gifs only yet..
The way I do this is I go through the list REALLY quick...
Cheers,
wOLV.
wOLVERINe wrote:Does it with jpegs only... I haven't had this with gifs only yet..
When you browse quickly your jpeg files, you have a freeze?
Do you have "Read ahead" & "Cache behind" option?
