EXIF orientated thumbnails are smaller than they should
Olivier_G
Post by Olivier_G »
I just noticed that EXIF orientated thumbnails (ie: taken in portrait) are smaller than they should, because their longer dimensions have to fit both X and Y (they are stored not turned, and must fit both Portrait and Landscape).
Isn't it possible to directly create and store thumbnails with the right orientation and dimensions (based on 'EXIF orientation' setting)?
XnView would then delete such thumbnails when user changes 'EXIF orientation' setting (which is not supposed to happen regularly). Another solution could be to store a rotation flag on thumbnail creation and compare it against current 'EXIF Orientation' setting on display (and recreate if different).
=> Thumbnail size would be maximized and XnView would not have to rotate those thumbnails on-the-fly on every display (ie: faster).
V 1.90 <x>
Olivier
Re: EXIF orientated thumbnails are smaller than they should
Olivier_G wrote:I just noticed that EXIF orientated thumbnails (ie: taken in portrait) are smaller than they should, because their longer dimensions have to fit both X and Y (they are stored not turned, and must fit both Portrait and Landscape).
Yes, i have not store final thumbnail to be able to rotate it easily!
If i change that, user should recreate thumbnails, but is it a problem :-) ??
Olivier_G
Post by Olivier_G »
xnview wrote:
Olivier_G wrote:XnView would then delete such thumbnails when user changes 'EXIF orientation' setting (which is not supposed to happen regularly). Another solution could be to store a rotation flag on thumbnail creation and compare it against current 'EXIF Orientation' setting on display (and recreate if different).
I think it would be fine (ie: the correct size advantage would be much greater than that small 'recreate' drawback in the long term use).
Olivier
PS: yes, I'm back... skimming through unread posts right now...
Olivier
Now i'm too close to the release, so i would like to not change that :-)
Olivier_G
Post by Olivier_G »
xnview wrote:Now i'm too close to the release, so i would like to not change that :-)
I agree with you... :mrgreen:
-> postponed.
Olivier
