RC2 : Wrong Orientation with CR2 Raw Thumbnails
otheli
Post by otheli »
CR2 Raw thumbnails (embedded) are shown in wrong orientation (EOS 400D)
They are rotated clockwise instet of counterclockwise. The JPG of the same picture und if you show in fullsize is o.k.
If you generate new thumbnails from the original raw, its o.k.
Olaf
This fault is with RC1
Re: RC1: Wrong Orientation with CR2 Raw Thumbnails
otheli wrote:Hello,
Olaf
Could you send me a CR2?
otheli
Post by otheli »
To witch E-Mail Adress? The File is about 10MB!!!!
Olaf
otheli wrote:To witch E-Mail Adress? The File is about 10MB!!!!
Olaf
Try <!-- removed //--> or do you have a ftp?
otheli
Post by otheli »
This Bug is open in RC2
Just tested
Olaf
otheli wrote:This Bug is open in RC2
Just tested
Yes, but i have problems between orientation of thumbnail and picture, on some CR2 files it's good but not on CRW, difficult to fix, i'll try to find a solution...
imforumman
Post by imforumman »
Sort of Confirmed.
I reported an issue some time ago here:
http://newsgroup.xnview.com/viewtopic.php?t=7912
But in the case I can reproduce, XnView does not show a badly rotated embedded thumbnail, it shows a thumbnail which is not rotated at all.
Pierre, do you still need a test file (350D) and screen shots?
Thanks!
imforumman wrote:Sort of Confirmed.
Thanks!
No now it's good...
imforumman
Confirmed fixed in 1.90 RC3.
Thank you so much!
