Icons go into mourning still !
—> Pierre
:) Good morning,
• We have 1.90 RC1 now, with a lot of cosmetical thingies, but it's still impossible to display icons in View and in a board of thumb nails properly, still that awful black background…
• That's really disappointing… I ought to resign XnView to display icons even in Total Commander now.
- The most icons I draw¦use¦store are 24 BPP. A trick might be found to view them correctly, I guess.
- This :bug: is there for ages…
:mrgreen: KR
V 1.90 RC3
ouistiti
Post by ouistiti »
:arrow: Clo
Support +++
:arrow: XnView
By the same way, is it possible to make the b(l)ackground for other files with transparency (Ex : Gif) modifiable so that the user can see if the picture is always correct with different backgrounds.
Friendly
Paul
1,77245385090552...
RHE suggestion for this…
:) Hello Paul !
• I think that THIS PROPOSAL could do the trick… :wink:
:mrgreen: Friendly,
RC1, not very better…
—> Pierre
:) Hello !
• Thank you to have attempted some improvements, according to that we said out the forum for the 24 BPP icons and the transparency thingy…
• With RC1, enabling the option the display is correct in View (please, see the Paul's wish above about the View BG and the link I gave in my answser…), but :
1. All 24 BPP icons are marked “32 BPP” everywhere, that indeed is quite wrong…
2. In a board of thumb nails, they are still black
3. Same in the preview, black:(
4. When blowing up such an icon in View, the black BG comes back as soon as the scale reaches 105% (I use a 1% step).
It stays beyond that value, and moreover the zoom-in function is quite perturbed, it seems
(the display jumps to an upper scale value after several 1% steps only).
- It occurs as well with the H. Quality enabled or not…
- The transparency is not restored when coming back to scale 1:1…
:mrgreen: KR
Re: RC1, not very better…
Clo wrote: 1. All 24 BPP icons are marked “32 BPP” everywhere, that indeed is quite wrong…
If you want transparency, so i must load them as 32bits!
AS is not IS
:) Again…
• "Loaded AS" is not they ARE 32 BPP, so all info shown for the 24 BPP icons is wrong !
• What about the other points ?
- I have set the display as 32 BPP in Windows, then the Preview is getting right,
but the thumb nails remain bad with the black BG…
:mrgreen: KR
Another snag…
—> Pierre
:) Hello !
• I just discovered another issue with the icons display :
- I've a small collection of 21² - 24 BPP icons I use in the file-lists of Total Commander, that works fine in this programme.
- In a board of thumb nails, these icons are displayed with a black BG - like the others -
but absolutely not viewable in Preview and in normal View, like shown below with the same outside blue BG:
- I tested with the transparency option “ON” and “OFF”, also with the screen colour-depth as 16 and 32 BPP,
that doesn't matter, same result.
- I send you this icon <JPG-type> as a sample…
¤ Else : Please, could you tell me if you have found any solution about the point #4 in my last but one message above ?
:mrgreen: KR
Re: Another snag…
Clo wrote: - In a board of thumb nails, these icons are displayed with a black BG - like the others -
Ok, i have the problem, i'll fix it
And the rest ?
—> Pierre
:) Hello !
• Thanks ! I'll retest that in the next RC.
I wrote above…
• Please, could you fix up this issue too? Thank you to try…
:mrgreen: KR
Re: And the rest ?
Clo wrote: I wrote above…
Strange i have not this problem...
Win XP ?
:) Hello !
• Did you test under Win XP-Pro ?
- You must set a 1% zoom-step
- This occurs in View only ! In Preview, it works.
• I can make a video if needed…
:mrgreen: KR
ouistiti
Post by ouistiti »
:arrow: Clo
I can reproduce that bug here, but randomly… :(
Friendly
Paul
1,77245385090552...
100%
—> ouistiti
:) Hello Paul !
• Thank you for checking ! Like you can see on the video (Pierre has it too), I can reproduce this by 100% !
• Maybe the OSs make the difference ? Still XP-Pro SP1 here…
:mrgreen: Friendly,
Still there
:) Hello !
• The Zoom :bug: is still there in RC3…
• Could someone more test and confirm ? TIA.
:mrgreen: KR
