B6: Links to libraries MSVCP71.DLL and MSVCR71.DLL
ckv
Post by ckv »
Pierre IlmImf.dll plugin is linked to MSVCP71.DLL and MSVCR71.DLL. Not a big deal, but I presume you still want to eliminate these dependencys.
Thanks for the beta. :)
ckv wrote:Pierre IlmImf.dll plugin is linked to MSVCP71.DLL and MSVCR71.DLL. Not a big deal, but I presume you still want to eliminathese dependencys.
Yes, IlmImf.dll can only be built by VC 2003 or 2005 :-(
I've just installed XnView 1.90 RC1 on a laptop with XP. When starting XnView an error message appars: xnview.exe - component not found. Message text says something like "The applicatioin could not be started since MSVCP71.dll was not found. Reinstallation of the application might solve the problem". After confirming the message box XnView starts.
In the above posts related or even similar issues have been reported. Do other people also have this problem?
@Pierre: The error message is not nice at all - I hope that you can do something about it.
helmut wrote:@Pierre: The error message is not nice at all - I hope that you can do something about it.
No, VC5 link with these new dll, in final release, exr plugin will be not added... (only as external file)
Good to read. :-)
->Closed (for now and hopefully forever) ;-)
