RC2: No tabs after tab option change.
marsh
Post by marsh »
A blank area for tabs is produced when between toolbar and menu when '[x]No thumbnail in tab'
is changed. The invisible tabs require setting Browser>Fullscreen>Viewer to see. Win2k.
Re: RC2: No tabs after tab option change.
marsh wrote:A blank area for tabs is produced when between toolbar and menu when '[x]No thumbnail in tab'
But how to reproduce it??
marsh
Post by marsh »
- Browser>Fullscreen>Viewer for <enter>
- [x]No thumbnail in tab' (it seems that change in any tab option creates problem.
-Problem doesn't occur with browser<>viewer mode
Can't reproduce it, but how to have it??
You open xnview, browser, and you click on a picture?
marsh
Post by marsh »
xnview wrote: Can't reproduce it, but how to have it??
Today, it is simpler than I described above. All I need to do to make tabs vanish:
Change 'Browser<>Viewer' to 'Browser>Fullscreen>Viewer' and display image in viewer. All with new ini file.
But how do you load the picture?
marsh
Post by marsh »
I selected picture in browser's file list and pressed <enter>. Win2k sp4; patched; No IE6.
marsh wrote:
xnview wrote:
marsh wrote: Today, it is simpler than I described above. All I need to do to make tabs vanish:
But if you press enter, you go to fullscreen?
Perhaps you could send me an email, i would like to send a test version..
Not very hard to reproduce. But the problem is not the empty area, the problem is that the tabs are not drawn at all.
A step by step description for reproduction:
1. In options Keyboard/Mouse > Switching modes change setting "Use double click to switch between" to "Browser > Fullscreen > Viewer".
2. In options Interface activate "No thumbnail in tab"
3. Confirm options change with "OK"
4. In XnView browser double click on a thumbnail. The image will be shown in fullscreen
5. In Fullscreen double click on image. XnView will switch to browser mode.
Between the menu and toolbar there's space where the tabs are supposed to be shown, but it's completely empty. :bug:
-> Confirmed.
And worse
:) Hello !
• I can confirm that :bug: , and also I guess that there is a pretty hitch in the file-tabs feature.
• Another funny :bug: with the tabs needs to have a button for RC2 in a button-bar of Total Commander 7 :
- Set that button with the option : [x] Run minimized
- Drag & Drop an image file (any) on the button,
- XnView opens - not minimized in the Win task-bar as it should -
:shock: Instead of the tab for the dragged file, there is a short TITLE-BAR with the Win colours for “Inactive” !
- I guess this is caused by a common defect in that function…
:mrgreen: KR
ouistiti
Post by ouistiti »
:arrow: Helmut
Confirmed.
:arrow: Clo
Confirmed.
Moreover, it's impossible to use the Win buttons to resize / minimize XnView, all is frozen except "Exit"
Friendly
Paul
1,77245385090552...
A pic---
—> ouistiti
:) Hello Paul !
• Thank you to have checked this ! Below, that is displayed here in the case :
:!:   :P
:mrgreen: Friendly,
Is it good with the sent test version?
marsh
Post by marsh »
It is fixed with the mailed test version. I see the tabs.
marsh
Post by marsh »
Still fixed.
