Hi you all,
I am not sure if this has been reported before, but the keyboard entry (i.e. ctrl+alt+numpad 1) for color labels is not working at my Toshiba laptop. Probably because the numpad has to be activated by pressing the FN-key as well. The ratings (i.e. ctrl+numpad 1) are working properly. May be a different keyboard combination could be assigned instead?
Birdman
XnView 1.90 <x>
Color labels: keyboard entry not working on laptop
Birdman
Dreamer
