1.90 : Blank screen after deleting pic in fullscreen mode
iycgtptyarvg
Post by iycgtptyarvg »
After you delete a picture in fullscreen mode you get a blank screen instead of the next picture. This is new (didn't happen in RC2).
Can someone supply me a link to the RC2 XnView.exe so I can use that instead?
Thx.
Re: 1.90 : Blank screen after deleting pic in fullscreen mod
iycgtptyarvg wrote:After you delete a picture in fullscreen mode you get a blank screen instead of the next picture. This is new (didn't happen in RC2).
Thx.
Is it with the final 1.90??
iycgtptyarvg
xnview wrote:Is it with the final 1.90??
Yes, it is.
- Double click a picture in the browser (to go to fullscreen).
- Press <DEL>
The screen remains blank.
PS
When pressing <F2> to rename the 'blank screen' it shows the name of the correct (read: next) picture.
PPS
If I first go to 'Viewer' mode and then to fullscreen mode, the bug doesn't occur.
Dreamer
Post by Dreamer »
Couldn't confirm.
Moved to bug reports.
Dreamer
Not confirmed
:) Hello !
• I cannot confirm as long as there are¦is some pic¦s file¦s in the folder.
- Here, I get the next file, as it should.
- When deleting the last file, I get a short blank effect (not the whole screen, ½ second) but I guess it's normal,
since there is nothing more to display…
- I tested with FS >> View and FS >> Browser as well, same result.
:mrgreen: KR
Post by Guest »
Maybe it's a combination of settings which cause this to happen for me. Here is my XnView.ini file :
http://rapidshare.com/files/14337418/xnview.ini.html
Could you create a link to your settings file so I can check whether they work for me?
marsh
Post by marsh »
You have not checked Options... File list>Images>[x]Show in preview column. Browser's fullscreen is a preview function.
Small ZIP
:) Hi !
• You can get my INI file HERE as a small ZIP archive…
• Hoping this helps.
:mrgreen: KR
marsh wrote:You have not checked Options... File list>Images>[x]Show in preview column. Browser's fullscreen is a preview function.
Yes, it's a problem with this option... I'll fix it in a 1.90.1
iycgtptyarvg
Yes! That fixed it for me!
I would never have guessed they were related!
Thx
