1.90 - No images to convert are selected
andrea.ippo
Post by andrea.ippo »
...even though in Misc tab of General preferences "Use all image files in current folder" is selected.
Instead, it works for SlideShows
I use Windows XP Pro + SP2
thanks for the great sw
Andrea from Rome
marsh
Post by marsh »
Confirmed. No entries are added for batch convert.
With slideshow, it can occur depending on number of subdirectories:
Normal=C:\in\test\
Problem=C:\in\test\test2\
Re: 1.90 - No images to convert are selected
andrea.ippo wrote:...even though in Misc tab of General preferences "Use all image files in current folder" is selected.
Andrea from Rome
Ok, i'll fix in a 1.90.1
Post by Guest »
Andrea from Rome
great, thanks :D
Post by Guest »
Andrea from Rome
great, thanks :D
1.90.1 works fine :D
