One pixel selection not possible
In XnView 1.90, selections with 1 pixel height or 1 pixel width are not possbile. The same applies for version 1.82.
Not possible---
• Hi !
• It seems it's not possible, I never saw any graphics soft able to do this…
• It was 3*3, now it's 2*2 like in M$ Paint. It has been discussed to get the smallest and Pierre implemented 2*2.
G.
Re: Not possible---
Hmm, you are right. I was sure that MS Paint would support a 1x1 selection, but in fact the smallest selection possible is also 2x2.Clo wrote:• It was 3*3, now it's 2*2 like in M$ Paint. It has been discussed to get the smallest and Pierre implemented 2*2.
Obviously there is a general limitation which I wouldn't have expected.
Exact, but, Jasc Paint Shop Pro version 9 supports a 1×1 selection !I was sure that MS Paint would support a 1x1 selection, but in fact the smallest selection possible is also 2x2.
Friendly
Paul
1,77245385090552... •
My "dear" 1x1
—> Ouistiti
Hello Paul !
Friendly,
… which costs … $$$ €€€ ?…Exact, but, Jasc Paint Shop Pro version 9 supports a 1×1 selection !
