Rotate exif in thumbnail...
most
Post by most »
I have a problem with the rotate exif function.
The thumbnail pictures in the browser windows of XnView 1.90.01 doesn't seem to show correct orientation.
I have several pictures which wrong in the thumbnail part but correct in the preview window and when I opened the picture.
I have turned of "Rotate based on exif".
Br Marcus
Re: Rotate exif in thumbnail...
most wrote:I have a problem with the rotate exif function.
Br Marcus
Try without 'Use embedded thumbnail', your embedded thumbnails have perhaps a bad orientation
most
it worked...
Post by most »
it worked now, but what is embedded thumbnail? what do have to do to update it?
Re: it worked...
most wrote:it worked now, but what is embedded thumbnail? what do have to do to update it?
Embedded thumbnail is a thumbnail in the file, and sometimes not good...
Dirk13
Post by Dirk13 »
can you recommend any tool to rotate the embedded thumbnail? Or does the current XnView version support this feature itself?
Thank you!
As far as I have understood the thumbnail has nothing to do with the picture's exif orientation. But what's the difference between
a) the option "Reset EXIF orientation value" in the JPEG Lossless Transformation window and
b) the setting "Change EXIF orientation ONLY when possible" in Tools -> Options -> Browser -> Misc. ?
Dirk13
Post by Dirk13 »
And, by the way, what is "For lossless operations make a backup" in Tools -> Options -> General -> File Ops?
Is this the point for creating .xnbak files?
Dirk13 wrote:Is this the point for creating .xnbak files?
yes
