Req: Compare Panel - Overlay thumbnail labels
JohnFredC
Post by JohnFredC »
Currently, the images in the Compare panel display each his own CRC and filename. It would be great, instead (or in addition, whatever), if the text of the images in Compare would display each his own thumbnail labels.
No need for a separate definition of labels for Compare. The labels defined for the thumbnails would be sufficient. A choice for a semi-transparent background color choices for the text and background would be great, too.
I am using the Compare panel more and more. This feature would help me a lot.
John
