1.90.2 - copy it and paste it to word will not work
Muck
Post by Muck »
hello
in the 1.8 it was possible to copy something and paste it into word now it is impossible.
i get in word this string "Bildschirminhalt erfassen-1" when i say paste it.
the workaround is to copy and paste it in paint then copy it again and paste in word... that works fine but is to much work.
please help me... thanks
muck
Re: 1.90.2 - copy it and paste it to word will not work
Muck wrote:hello
Do you copy from edit mode or browser mode?
Muck
Post by Muck »
Hi
i make it from edit mode. let me descripe what i do:
i make a screen capture... then "strg" + "c" ... change to ms word and "strg" + "v" ... then i get the text mesasge and not the picture :-(
when i make the same to ms paint it works fine
thanks you
Muck
