Right-button dragging file option
Dret
Post by Dret »
This program is... FANTASTIC...!! It gives me the possibility to finally replace ACDSxx o my pc... with a portable-free application. :D
But one thing I would like to suggest you: :wink:
is possible to include a Right-button dragging file option (to move files from the browser area to the tree-folder side panel) that allows, on button releasing , to choose between "Move in" and "Copy in" operation?
By default the Left-button draggin (Win Os) consist in a "Move in" operation, but become a "Copy in" operation when you are dragging file into folder located in other drive units. :|
This possibility to choose better the dragging operation is the only feature of ACDSxx software that I didn't find in your application. :(
It's a little thing but very usefull when you have to move files quickly (by a simple dragging) between many drive units.
Thank You again for your fantastic work!!
Bye!!
(Sorry for my English... it's orrible! I Know...!! :shock: )
Re: Right-button dragging file option
Dret wrote:This program is... FANTASTIC...!! It gives to me the possibility to finally replace ACDSxx o my pc... with a portable-free application. :D
Thank you :-)
And ok, added in my todo list :-)
Dret
Post by Dret »
Thanks a lot....!!
:D
Dret
Post by Dret »
Excuse me...!
I forgot to include: it's possible to extend the right-button dragging options (previuosly exposed in my original post) inside the tree-folder panel too?? (See image below)
For moving\copying quickly folders like in Explorer file manager.
Thanks!! :D
Bye.
Don't Panic!!!
