Once more: EXIF Orientation
wolfbartels
Post by wolfbartels »
I have a camera with an orientation sensor. I make 3 fotos, one with the camera turned to left, one upright and one turned to right. In ordinary viewers I can verify the 3 different orientations. Viewing these fotos in XnView 1.90.2, all 3 fotos show upright automatically. So far, so good, it is a nice feature.
Now my question. Why do EXIF-Data of all 3 fotos show the same
Ausrichtung: Oben-links (1) ???????
Doesn't 'Ausrichtung' mean 'orientation' in german version?
(In german Help 'Ausrichtung' appears only once in a different context?)
Re: Once more: EXIF Orientation
wolfbartels wrote:I have a camera with an orientation sensor. I make 3 fotos, one with the camera turned to left, one upright and one turned to right. In ordinary viewers I can verify the 3 different orientations. Viewing these fotos in XnView 1.90.2, all 3 fotos show upright automatically. So far, so good, it is a nice feature.
Please send me the files, i cant reply without to check them :-)
wolfbartels
Please find the files under http://www.wolfbartels.de/orientation
If you prefer me to send these files in another way, please inform me how.
wolfbartels wrote:Please find the files under http://www.wolfbartels.de/orientation
Ok, it's normal. If you have "auto rotate EXIF", the picture is rotated, and orientation flag is reseted, try by disabling this option...
Karl02
Post by Karl02 »
In my opinion it's confusing that the displayed value of the Exif orientation tag is changed if the image is temporarily rotated for viewing when the option "Rotate images based on EXIF orientation" is activated. See Only tooltip shows correct EXIF Orientation value.
Furthermore, I would like to edit the orientation tag manually as a variant of a lossless rotation. See also:
- Edit Exif-Data
- EXIF lossless rotation
Especially in this case the changed orientation tag value would be very confusing.
-- Karl
Karl02 wrote:In my opinion it's confusing that the displayed value of the Exif orientation tag is changed if the image is temporarily rotated for viewing when the option "Rotate images based on EXIF orientation" is activated. See Only tooltip shows correct EXIF Orientation value.
- Edit Exif-Data
The problem is, if i don't change the orientation flag, and you save the picture in jpeg, you'll have a picture rotated 2 times
I've checked, and now it's fixed with the 1.92 :-)
Karl02
Post by Karl02 »
I have problems with the following images:
Image Image Image Image
They have Exif orientation tags from 1 to 8 and should be rotated to an upright position. However, XnView v1.92 does not rotate them. Only the displayed orientation tag ist changed to "1", which I still consider as confusing. It would be better to change the saving procedure.
All pictures in a rar archive here: http://newsgroup.xnview.com/viewtopic.p ... 33#p103253
-- Karl
Karl02 wrote: They have Exif orientation tags from 1 to 8 and should be rotated to an upright position. However, XnView v1.92 does not rotate them. Only the displayed orientation tag ist changed to "1", which I still consider as confusing. It would be better to change the saving procedure.
Ok, i check...
Karl02
Post by Karl02 »
This problem has been fixed in v1.92.1. :D
The above test images are now rotated correctly to an upright position, and the EXIF orientation flag is displayed as it is saved in the file.
One minor issue: When changing the option "Rotate images based on EXIF orientation", the images in the thumbnail browser are not rotated immediately or after selecting "refresh", but only after changing the directory.
-- Karl
Karl02
Post by Karl02 »
The minor issue is still present in XnView v2.32 (2015-03-16). :bug:
1) After changing and saving the rotation option, the images in the thumbnail browser should be rotated immediately.
2) Another issue in that context:
a) When editing the EXIF orientation tag manually in the EXIF pane, this value should be highlighted as long as it is not saved.
b) There should be a "Save" button to save changes.
c) When selecting another picture without saving the changes, a pop-up window appears with the question "Do you want to save your changes?" and the buttons "Yes" and "No". There should also be a button "Cancel" to stay at the current image and check the changes.
-- Karl
