Can't play slideshow since 1.90
jeschg
Post by jeschg »
I was saved all my photos into *.sld file. After I first saved it and view it, it's no problem. But afterward, when I play that file, it's only show black screen for me, it can't show any photos. I tried my 2 notebooks also the same. This problem only found since 1.90 version.
Please kindly fix it. Thks so much
Re: Can't play slideshow since 1.90
jeschg wrote:I was saved all my photos into *.sld file. After I first saved it and view it, it's no problem. But afterward, when I play that file, it's only show black screen for me, it can't show any photos. I tried my 2 notebooks also the same. This problem only found since 1.90 version.
How do you use it? By clicking on the .sld?
jesschg
Post by jesschg »
yup, I'm just clicking *.sld directly. Can't clicking it directly since 1.90?
jesschg wrote:yup, I'm just clicking *.sld directly. Can't clicking it directly since 1.90?
Sorry but i don't understand, you tell that you click, and that you can't click on 1.90????
Dreamer
Post by Dreamer »
Confirmed.
- select few files (images, JPG)
- press Ctrl+L
- save slide show as .sld (to root dir.)
- run saved .sld file
= result is only a black screen (also the first time)
If you have enabled sound, it is playing, but the bug is present also if sound is disabled.
Dreamer
Dreamer wrote: - run saved .sld file
By clicking on it??
Dreamer
Post by Dreamer »
Yes. I can reproduce this bug only if "relative paths" option is enabled.
Dreamer
Dreamer wrote:Yes. I can reproduce this bug only if "relative paths" option is enabled.
Oh ok, it's normal because current path is not always path with .sld!
Dreamer
Post by Dreamer »
Sorry, I don't understand, if I create .sld slideshow, run it and I have just black screen, is it normal - not a bug??
Dreamer
Right a bug, but is it new? Do you have the same behaviour in 1.82.4??
Dreamer
Post by Dreamer »
xnview wrote:
Dreamer wrote:
xnview wrote: Oh ok, it's normal because current path is not always path with .sld!
But I tried it and I have error dialogs with 1.82.4, but in 1.90.2 there are no dialogs, just a black screen.
Dreamer
And 'suppress read errors' is not enabled?
Dreamer
Post by Dreamer »
I tried to toggle all slideshow options.
If 'suppress read errors' is disabled, there is an error dialog also in 1.90. But this dialog is strange:
I use freeCommander (file manager, beta version). I tried to run it from explorer and it works. :shock:
So it's a freeCommander bug? If so, it's really strange, all other file types work good.
Dreamer
Dreamer wrote:I tried to toggle all slideshow options.
The problem is the current directory when you use relative path and start the sld!
Dreamer
Post by Dreamer »
OK, but where is the problem, in freeCommander or in XnView?
I tried other file manager and it work good too, so is it freeCommander?
Dreamer
