8BF Plugins aren't listed
plugins
i cant get the 8bf plugins that i put in the 8BF folder to show in xnview. Can someone help?
Re: 8BF Plugins aren't listed
And in Options/System integration/Plugin?plugins wrote:i cant get the 8bf plugins that i put in the 8BF folder to show in xnview. Can someone help?
Re: Directory
The short notation "Options/System integration/Plugin" translates to:plugins wrote:Where is that?
Choose menu "Tools > Options", then category "System integration", tab "Adobe PlugIns". There you add and remove Adobe 8 Plugins.
- Forum Librarian
@guest:
Keep in mind that there are two different kinds of plug-ins in the menu:
See also: Good plugin, doesn't work with xnview
- Browser Mode: Tools » Plugin
- View Mode: Filter » Adobe Photoshop Plug-In... Ctrl+G
