Convert PDF to TIFF
Salim
Convert PDF to TIFF
Post by Salim »
First off all thanks a lot for your work, it will be very usefull for me if manage to make it working.
I try to generate a Fax from a PDF. The format is TIFF CCITT G4.
My commande is
nconvert -multi -c 7 -out tiff FaxG4.tiff fax.pdf
Any help will be extremely appreciated ;-)
Salim
The return
Post by Salim »
The return is "Erreur de segmentation"
I'm working on Suse Linux 10.1
Thanks
Re: The return
Salim wrote:The return is "Erreur de segmentation"
Thanks
Do you have the last version of nconvert?
Salim
Reply
Post by Salim »
Yes I have !
But I finally solve my problem by using an other program ;-)
Thanks
