could someone post links to tutorials or documentation for command line
commands, options, switches, syntax? can't seem to find any. would like to
look through it before installing.
thanks,
BabaG
n00b command line help?
- Forum Librarian
Info » Command line help...
Usage : xnview [options] files ....
Options:
-all : Open a window for each picture
-browser : Launch the browser
-slide <file> : Launch slide show
-full : Start in fullscreen
-fi : Force Fit to Image
-fa : Force Xnview to Fit Image
-ini <file>
-scan
-capture
-clipaste
You can use 'xnview <folder>' to start browser.
foxyshadis
- Forum Librarian
foxyshadis wrote:You'd probably want nconvert for that. Or is that what you were asking for help with?
- Topic #3735: Command line options of nconvert 4.51
- Topic #3857: How to use nconvert
- Topic #11727: XnConvert v1.04
- http://download2.xnview.com/Nconvert-win.zip
- http://www.xnview.com/beta/XnConvert.zip
