"F2" renames File instead of Folder
When using F2 to rename a folder, the dialog for renaming file appears, which is wrong.
To reproduce in XnView 1.90.2:
In XnView browser
1. Click on a file (thumbnail)
2. Press "F2" --> Dialog "Rename file" appears (Correct)
3. Click on folder in the folder tree
4. Press "F2" --> Dialog "Rename" appears (Bug :bug:)
Dreamer
Post by Dreamer »
Confirmed, also on folder in the file list (if enabled).
Dreamer
Default=ticked
:) Hello !
• Hmm… What about untick the box : Options >> Browser >> Use dialogue to rename file ?
- It's ON by default here, it seems, put to OFF, that works in the tree, no more dialogue.
:mrgreen: KR
Re: Default=ticked
Thank you, Dreamer and Clo for confirming.
Clo wrote:- It's ON by default here, it seems, put to OFF, that works in the tree, no more dialogue.
When unchecking the option "Use dialog to rename" the problem no longer occurs, so this is a possible workaround. Sure enough the above problem should be fixed.
