Rating and Colour label - removing folders doesn't work
Dreamer
Post by Dreamer »
To reproduce just drag any folder to any Rating and/or Colour label 'sub-folder' and then try to remove it by shortcut or main menu - as image.
XnViw 1.90.3, Win XP SP2
Dreamer
Re: Rating and Colour label - removing folders doesn't work
Dreamer wrote:To reproduce just drag any folder to any Rating and/or Colour label 'sub-folder' and then try to remove it by shortcut or main menu - as image.
I'm a bit surprised to read that you can add folders to categories, ratings and colour labels. My guess is that this has never been tested.
And yes, once the display of folders in the file list is activated (Tools > Options > Browser > File list > File list > Folders > Show item in view 'Thumbnail'") one can easily reproduce your bug: You can add a folder to categories, ratings, or colour labels by dragging but you cannot remove it from ratings and colour labels. Removing from categories works.
