7z problem
yhk
7z problem
Post by yhk »
If a folder becompressed into the 7z file,
in XnView 1.90.3 the tpye is unknow
http://homepage13.seed.net.tw/web@3/yhk/0.7z
without folder,it will be normal
http://homepage13.seed.net.tw/web@3/yhk/1.7z
Image[/img]
Fine here…
:) Hello !
• I can't confirm, it works fine here, the only snag is that with the simple thumb nail view
(no label, only the file name below the thumb nail), the name is wrongly displayed.
- The reason is that (it seems) 7Z writes the name as UTF8 inside the archive data,
while XnView doesn't support UTF8 there (yet)
- However, using Thumb nails and details, all is OK, the files are rightly described, and the usual ANSI charset is used…
• I checked too with a *.SQX archive - I use this format a lot- (with the same *.ico files packed inside as solid),
and this works like a charm too…
:mrgreen: Kind regards,
