Print problems: Picture size
Stv
Post by Stv »
Hi! I'm currently using XnView 1.90.3
It's very good for image viewing.
But when I tried to print, found some errors :(
When I choose Print.../Layout/Page Layout (Single - Custom), I can decide the printable picture's size. There is the input box for height and width. But the texts are swapped. If i change the height, the picture's width is changing. :?
And the maintain aspect ratio is very helpful, but I think it should change the height/width numbers every time, when I check it. (or display it in another text box). So that I should know, how big the image's size will be.
And the last thing could be a feature request. If I want to print 2 or 4 pictures on a page, I can't do it now (or I couldn't find it, how to do it). This is not a big problem, but it should make printing photos faster. And that's a very good thing in the age of digital photos :)
Besides these problems, the software is great. Thanks for creating it. :)
Re: Print problems: Picture size
Stv wrote:Hi! I'm currently using XnView 1.90.3
Thanks, and ok i'll check the problems
dlenne
swap of print width/height dependent on printing width
Post by dlenne »
I found, that everything is o.k. as long as the printing width, given in cm, isn't bigger than the original image height, given in px, divided by 118.
Can anyone else reproduce this?
Could it depend on the printer model (mine is a hp 959c)?
My machine is a PII-350 running W2K.
This holds for Version 1.91.6.
Post by Guest »
Bug is still present in 1.92!
Pit
How to reproduce it? I have a correct behaviour...
Post by Guest »
xnview wrote:How to reproduce it? I have a correct behaviour...
See description in Stv's post.
Pit
I can't reproduce it
