Hi everyone...
When i insert into a picture a text, for example this:
"Hello" in comic sans ms, bold and italic, XnView is allways cutting a part of the last letter - in this case the last letter ist "o" and after inserting the text, the "o" is not complete inserted.
The right part of "o" is not visible!
Thanks for reading this,
Daniel germany
Text inserted into image is truncated
Correct and not…
—> DanielV
Hello !
• It depends on which kind of letter is the last one, if it's a lowercase “o”, it's correct here.
- BUT if the last character is a capital “O”, you are right and I confirm, like shown below :
• I used the same font, both italic and bold, and the same “Almond” background.
• I tested also with the new “Paint” tool, there is the same defect. It's worth to test with other letters too…
• Hence, despite it's not usual to write a cap. letter at the end of a word (at least in French and English…),
one can say that's a
Note : It occurs with all fonts…
VG
ouistiti
—> DanielV
Confirmed !
As a temporary workaround, you could add a space foreward the last character…
- However, Pierre might fix up this by adding a hard-coded right margin valid for W which is the widest character, it seems…
Friendly
Paul
Confirmed !
Friendly
Paul
1,77245385090552... •
Tiotrag
Its me DanielV, i forgot my password and register as a new user:-(
@ Claude
Yes, thats what i mean!
Ok sorry, i didn't test this on oter grafik-programs so i didn't no they have the same "bug".
Some times i write like this: "Hello!" ...and the "!" sign is olso cutted in the right-top corner
I use a empty space to avoid this problem, i just want to inform about this BUG but it seams it is no BUG
I raported long time ago about the 1x1px problem. I sometimes need a 1x1px image but with XnView i coudn't make it! With the new version 1.90.2 the smallest image is 2x2px i can make.....ok i use irfanview for that
Thanks for helping, XnView is my favorit an main grafikprogramm, sometimes i use photofiltre to make some images with mask.
Bye Daniel from Nürnberg/Alemand
@ Claude
