Autofit videos & hiding control bar
Post by Guest »
Hi
when i open a video in xnview i want to have that it will be resized to window size automatic like pictures, is that possible?
i don't need the control bar (Play/Stop, Time, Volume,...) so i want to know if i can hide it to win more space vor vids.
i know i can open a video, then middle click on it for fullscreen and then fit it's size to fullscreen per context menu, but that is too complex i think....
Re: Autofit videos & hiding control bar
Anonymous wrote:Hi
On the video, you have a right click menu to fit it.
For the control bar, perhaps a global setting for view/preview is needed...
Post by Guest »
oh..
would be to cool when in xnview would be implemented the option to play videos automatic in fullscreen with autofit.
vommie
Post by vommie »
Oh, and i forgot: videos doesn't loop, is this a bug or normal?
Post by Guest »
is it possible to auto fit video to window for all videos?
now must tick it for every video
Anonymous wrote:is it possible to auto fit video to window for all videos?
Right, the setting is not kept... i'll fix it
pepemosca
Post by pepemosca »
I still have the problem in 1.91.5 in Windos Vista Home Premium.
The "fit to window" is set ON all the time, but sometimes the video is not fitted.
I still don't get it when it happens the problem.
I'm playing mostly AVI (M-JPEG) files.
Tell me what to check :)
Thanks!
pepemosca
Post by pepemosca »
I think that I have the "when".
The problem apears when I do this:
1. Open the XnView
2. Go to some folder with some photos and a video (the video goes to the end because starts with M and the images with I).
3. Double click on the first picture. I'm not in the fullscreen mode.
4. Pass the pictures with "Page Down"
5. When I get to the video: boom! The problem. The video is not fitted to the window.
See this screenshoot:
Hope that helps :)
XnView 0.97.1 64bits (Oct 13 2020)
Windows 10 20H2
pepemosca
Post by pepemosca »
Any ideas why?
Do you want me to do some tests?
Thanks!
Windows 10 20H2
pepemosca
Post by pepemosca »
Now works great! In the 1.91.6!
Thanks!
Windows 10 20H2
