progress on cr2 file corrdinates divided by 2?
BabaG
Post by BabaG »
just checking. is there any progress on the issue of cropping
coordinates having to be divided by two on cr2 files? or the
resulting cropped image being 1/4 size? has it been reproducable?
do you need a cr2 file to test?
thanks,
BabaG
Re: progress on cr2 file corrdinates divided by 2?
BabaG wrote:just checking. is there any progress on the issue of cropping
coordinates divided by 2???? Do you load the CR2 in full size?
BabaG
Post by BabaG »
i haven't done anything that would cause the image to load
smaller than its original size. this info is a follow up on this
thread:
http://newsgroup.xnview.com/viewtopic.php?t=12401
are there special options or switches i need to employ to get
a cr2 file to load at its native resolution?
thanks,
BabaG
BabaG wrote:i haven't done anything that would cause the image to load
thread:
thanks,
BabaG
Ok, i'll upload soon a version...
BabaG
Post by BabaG »
woo hoo! thx!
