'format not determined' warning does not appear
marsh
Post by marsh »
When opening an unsupported file, the warning message "Format of the file <abcd.efg> could not be determined" usually appears.
The new problem:
The warning is not shown when there are multiple files in a directory.
The warning is shown, as expected, when only 1 file is in a directory.
Re: 'format not determined' warning does not appear
marsh wrote:When opening an unsupported file, the warning message "Format of the file <abcd.efg> could not be determined" usually appears.
The new problem:
How do you try to open it?
marsh
Post by marsh »
The new problem:
Using browser + <enter>
Other settings:
Switching modes: browser>fullscreen>viewer.
Open action: All other files: Open in Xnview.
Browser's small toolbar filter set to all (for displaying non-image files).
I could reproduce your problem with default settings:
1.) Browse a folder with one single non-image file.
2.) In context menu (right mouse click) choose "Open".
--> A message box "Format of the file <xx> could not be determined" appears
3.) Make a copy of the non-image file in the same folder (there are two non-image files in the folder, now).
4.) In context menu choose "Open".
--> No message box appears. :bug:
Note: Amazing that you (marsh) have found out that it makes a difference whether there is one single file or whether there are multiple files!
