In view mode and thumnails mode the screen does not fit the screen, there is a blanc space at right. Screenshot
I am in 1 680 x 1 050 with Windows Vista.
Resizing window bug
Re: Resizing window bug
Strange i have not the problem. Do you have the same problem on lower resolution?Icarus wrote:Hello,
eweryboooody
Resizing window bug sounds good:
Is it ok if I post an addition to that or rather a new report?
I turned Auto Image Size to "Fit window to image" and turned "Force XnView to Fit Image" On! But still the window in not resized if I switch to another image.
on top of that there is another option missing: I mean I WANT the small window if the image is small but if the image is bigger than the screen, I'd like to have xnview AND the image to fit the screen!
"Fit window to image small only" ?!
