XnView used to open PPT and PPS but not anymore in versions 1.90.2 and 1.90.3.
Why???
Power Point (PPS PPT) not anymore?
Raphael Barbosa
- Contact:
Raphael Romero Barbosa
Raphael Barbosa
- Contact:
Pierre replied in another topic:
Enable option/general/startup/Use all formats. In FAQ "Does XnView support graphic format .xyz?" you'll find more info.
Basicaly, it's:
* General>Startup>[ ]Use all formats available
o The most popular 150 file types out of about 500 available will be used when this option is off (the recommended default setting).
o When enabled, extra file types will also appear in 'supported formats list' in program's menu.
Basicaly, it's:
Last edited by Raphael Barbosa on Thu May 03, 2007 9:00 pm, edited 1 time in total.
