Change TREE text color and background color?
ghost zero
Post by ghost zero »
Is there a way to change the TREE text color and background color? I want to change it to match my preview and browser colors.
ghost zero
is it possible?
BG, no font
:) Hello !
• It's something I proposed a while ago in THIS MESSAGE
- Apparently, only the BG-colour can be set from the INI, the rest is pending… :|
• Feel free to *bump* the thread linked above, and support the entire proposal…
:mrgreen: KR
JohnFredC
Re: BG, no font
Post by JohnFredC »
Clo wrote:- Apparently, only the BG-colour can be set from the INI, the rest is pending… :|
Hi Clo... again you catch me "unawares"...
What is that INI setting? I'm looking but can't see it in there.
Regards
John
Pierre's statement…
:arrow: JohnFredC
:) Hello John !
• It's about this Pierre's statement. Please, see the Dreamer's message above too.
• However, it seems that it is not added automatically - I've not it here -
but maybe you could add it by hand in the appropriate section…
• Anyway, a GUI like I showed in the linked message above should be THE solution, shouldn't it be ?
:mrgreen: KR
ghost zero
can this be done via an ini tweak for faster support?
ghost zero wrote:can this be done via an ini tweak for faster support?
You have TreeBackColor & TreeFontColor
JohnFredC
Post by JohnFredC »
Wonderful! Finally!!!
Thanks!
John
klaus2
Post by klaus2 »
When using the TreeBackColor tweak on XP:
does anybody have a problem with the selection colors for the treeview items?
(mines are lost .. i cannot see then any longer the selected item's selection color)
SimesB
Post by SimesB »
Yes I have that problem too, I posted it in the bug section ...
http://newsgroup.xnview.com/viewtopic.php?t=13106
ghost zero
any progress on fixing it?
ghost zero wrote:any progress on fixing it?
I'll release soon a 1.91.3
ghost zero
btw what kind of code do we use for colors? its not rgb or html...
TreeBackColor=
TreeFontColor=
JohnFredC
Post by JohnFredC »
The last few posts in this thread are relevant to this discussion.
John
klaus2
Post by klaus2 »
TreeBackColor with highlighted selection is implemented now with 1.91.3 :-)
just a very little little thing:
i would suggest to use White as selection font color
(= same as not using this tweak)
otherwise you have black selection font on dark blue selection background color, which ist hardly readable
