1.91: folder loads twice after selected using keyboard
Bugs, defects, GPFs. Nothing else.
Moderators: Olivier_G, Dreamer, XnTriq, helmut, xnview
Postby pch » Sat May 19, 2007 9:39 am
There is a small problem with the tree pane in XnView 1.90.3 and 1.91 (on Windows 2000).
When you use cursor keys to select a folder in the tree pane, XnView loads the selected folder twice. It starts loading the thumbnails, but then, after a few milliseconds, it clears the thumbnail pane and starts loading the same folder again.
It doesn't happend when you click the folder.
pch
Postby marsh » Wed May 23, 2007 1:34 am
Confirmed.
marsh
Return to Bug Reports
Who is online
Users browsing this forum: No registered users and 0 guests
